ROKAE xMate CR18
ROKAE xMate CR18 specs:
Brand ROKAE
Model xMate CR18
Payload 18 kg
Reach 1062 mm
Repeatability 0.03 mm
Weight 40 kg
Start programming ROKAE xMate CR18
ROKAE xMate CR18 description
Watch ROKAE xMate CR18 in 3D
ROKAE xMate CR18 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot ROKAE xMate CR18 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Trimming, Deburring, Additive manufacturing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE xMate CR18 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE xMate CR18 applications programmed with SprutCAM X Robot
How to start programming ROKAE xMate CR18 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including ROKAE. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the ROKAE xMate CR18, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE xMate CR18, please contact the manufacturer or local supplier.
