Robotic welding with SprutCAM X Robot
Giugno 17, 2024
SprutCAM X Welding Robot
Robotic welding is a type of automated welding where a welding robot does the work. These are special industrial robots that are usually stationary. They’re used to do the same welding operation over and over again. Automatic welding is where all the welding parameters are controlled. You can make manual adjustments between welding operations, but not during welding. Robotic welding is a form of automatic welding that utilises a robot to perform welding operations and fabricate geometries according to a pre-programmed sequence.
SprutCAM Robot Welding Free version is available for evaluation during free 30-day period. Full version has complete library of robots and CNC milling machines which help to save time by using the library’s preconfigured equipment. Our website contains vast knowledge base of on-line courses, tutorials, and forums about SprutCAM software solution for welding.
SprutCAM X Welding Robots have following benefits:
1) Efficiency. The average return on investment for a welding robot is 10 to 18 months.
2) Increase production capacity. A robot can replace 2 or 3 people in your manufacturing workflow. It is usable in environments where people cannot physically work.
3) High quality products. You get clean, strong weld joints and reduce the amount of substandard work.
4) New opportunities. Robots allow you to launch new products without significant investment in equipment modernization.
In order to work it with SprutCAM it is necessary to use SprutCAM’s solutions to design and simulate welding operation on a PC. It is safe and does not require a real robot for testing.
1) Import a 3D model. SprutCAM X Robot supports all popular 3D formats. In addition, you can create a model in our integrated CAD.
2) Choose a robot from the library
SprutCAM Robot already contains models of the most popular robots.
You can assemble your robot cell for welding in SprutCAM Robot. Or you can use our advanced MachineMaker solution.
3) Enter welding points
Simply enter them in your 3D model.
SprutCAM Robot automatically calculates the shortest and safest tool path for welding.
4) Get the result you want
SprutCAM X has an extensive library of 3D machines and postprocessors.
SprutCAM X doing 8 axis welding, a case from China
