AUBO iS20
AUBO iS20 specs:
Brand AUBO
Model iS20
Start programming AUBO iS20
AUBO iS20 | SprutCAM X
AUBO iS20 description
Watch AUBO iS20 in 3D
AUBO iS20 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot AUBO iS20 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Deburring, Pick and place.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how AUBO iS20 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
AUBO iS20 applications programmed with SprutCAM X Robot
How to start programming AUBO iS20 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including AUBO. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the AUBO iS20, please contact the manufacturer or local supplier.
If you have questions about purchasing the AUBO iS20, please contact the manufacturer or local supplier.
