ROKAE xMate CR18-C
ROKAE xMate CR18-C specs:
Brand ROKAE
Model xMate CR18-C
Payload 18 kg
Reach 1062 mm
Repeatability 0.03 mm
Weight 38 kg
Start programming ROKAE xMate CR18-C
ROKAE xMate CR18-C description
Watch ROKAE xMate CR18-C in 3D
ROKAE xMate CR18-C applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot ROKAE xMate CR18-C can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Trimming, Robot welding, Pick and place, Painting. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE xMate CR18-C can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE xMate CR18-C applications programmed with SprutCAM X Robot
Spraying
How to start programming ROKAE xMate CR18-C with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including ROKAE. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the ROKAE xMate CR18-C, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE xMate CR18-C, please contact the manufacturer or local supplier.
