MOTOMAN MPX3500
MOTOMAN MPX3500 specs:
Brand MOTOMAN
Model MPX3500
Payload 15 kg
Reach 2700 mm
Repeatability 0.15 mm
Weight 590 kg
Start programming MOTOMAN MPX3500
MOTOMAN MPX3500 | SprutCAM X
MOTOMAN MPX3500 description
Watch MOTOMAN MPX3500 in 3D
MOTOMAN MPX3500 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MOTOMAN MPX3500 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Polishing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MOTOMAN MPX3500 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MOTOMAN MPX3500 applications programmed with SprutCAM X Robot
How to start programming MOTOMAN MPX3500 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including MOTOMAN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the MOTOMAN MPX3500, please contact the manufacturer or local supplier.
If you have questions about purchasing the MOTOMAN MPX3500, please contact the manufacturer or local supplier.
