MOTOMAN HD7
MOTOMAN HD7 specs:
Brand MOTOMAN
Model HD7
Payload 7 kg
Reach 927 mm
Repeatability 0.02 mm
Weight 47 kg
Start programming MOTOMAN HD7
MOTOMAN HD7 | SprutCAM X
MOTOMAN HD7 description
Watch MOTOMAN HD7 in 3D
MOTOMAN HD7 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MOTOMAN HD7 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Grinding. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MOTOMAN HD7 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MOTOMAN HD7 applications programmed with SprutCAM X Robot
How to start programming MOTOMAN HD7 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including MOTOMAN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the MOTOMAN HD7, please contact the manufacturer or local supplier.
If you have questions about purchasing the MOTOMAN HD7, please contact the manufacturer or local supplier.
