ESTUN ER8-1500-CW
ESTUN ER8-1500-CW specs:
Brand ESTUN
Model ER8-1500-CW
Payload 8 kg
Reach 1500 mm
Repeatability 0,08 mm
Weight 286 kg
Start programming ESTUN ER8-1500-CW
ESTUN ER8-1500-CW | SprutCAM X
ESTUN ER8-1500-CW description
Watch ESTUN ER8-1500-CW in 3D
ESTUN ER8-1500-CW applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ESTUN ER8-1500-CW can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Deburring, Pick and place.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ESTUN ER8-1500-CW can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ESTUN ER8-1500-CW applications programmed with SprutCAM X Robot
How to start programming ESTUN ER8-1500-CW with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including ESTUN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the ESTUN ER8-1500-CW, please contact the manufacturer or local supplier.
If you have questions about purchasing the ESTUN ER8-1500-CW, please contact the manufacturer or local supplier.
