Borunte BRTIRUS0707A
Borunte BRTIRUS0707A specs:
Brand Borunte
Model BRTIRUS0707A
Payload 7 kg
Reach 700 mm
Repeatability 0.030 mm
Weight 55 kg
Start programming Borunte BRTIRUS0707A
Borunte BRTIRUS0707A | SprutCAM X
Borunte BRTIRUS0707A description
Watch Borunte BRTIRUS0707A in 3D
Borunte BRTIRUS0707A applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot Borunte BRTIRUS0707A can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how Borunte BRTIRUS0707A can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
Borunte BRTIRUS0707A applications programmed with SprutCAM X Robot
How to start programming Borunte BRTIRUS0707A with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including Borunte. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the Borunte BRTIRUS0707A, please contact the manufacturer or local supplier.
If you have questions about purchasing the Borunte BRTIRUS0707A, please contact the manufacturer or local supplier.
