Fanuc R-2000iC-125L
Fanuc R-2000iC-125L specs:
Start programming Fanuc R-2000iC-125L
Fanuc R-2000iC-125L | SprutCAM X
Fanuc R-2000iC-125L description
Watch Fanuc R-2000iC-125L in 3D
Fanuc R-2000iC-125L applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot Fanuc R-2000iC-125L can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how Fanuc R-2000iC-125L can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
Fanuc R-2000iC-125L applications programmed with SprutCAM X Robot
How to start programming Fanuc R-2000iC-125L with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including Fanuc. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the Fanuc R-2000iC-125L, please contact the manufacturer or local supplier.
If you have questions about purchasing the Fanuc R-2000iC-125L, please contact the manufacturer or local supplier.
