Lathe features in SprutCAM
All types of turning operations
Lathe canned cycles
Streamlined CNC programming workflow
SprutCAM calculates lathe toolpaths and all other machining processes using the native kinematics of the CNC machine.
What does this mean to the user?
This means that collisions between machine axes as well as the workpiece are handled automatically during toolpath calculation.
You do not need to postprocess the NC code to simulate the real-world result. All machine movements are visible immediately after the toolpath calculation.
CNC programming becomes visual, workflow is streamlined.
Further, thanks to this feature the user can save even more machine time by fine tuning of the machine. For example reducing cycle time by optimizing the tools location in the turret.
Lathe canned cycles
Further, thanks to this feature the user can save even more machine time by finel tuning of the machine. For example reducing cycle time by optimizing the tools location in the turret.
Lathe programming time-savers
Save time with toolpath preview
SprutCAM shows a toolpath sketch even before the toolpath calculation. So programming is getting faster.
Setting the approach interactively
Useful for obtaining easy readable values in the G-code.
CNC machinists will appreciate it.
Drag-and-drop contour editing
Threads database
Threads database
Advanced turning programming in SprutCAM
