Swiss-type toolpath calculation and machining simulation
Multichannel features
Sync points setup
Each MTM node works with a separate controller / channel, using its own program.
Therefore, it is necessary to create NC code for each machine controller / channel.
These programs require synchronization; pausing is necessary.
SprutCAM has the sync points setup feature for this purpose. Sync points can be put anywhere in the NC code.
Machine time optimization
Evaluation and load balancing on each of the control channels.
Distribution of job between channels.
Toolpath calculation and simulation
Auxiliary operations
Sync points setup
Multichannel machining examples
