How Grinding / Polishing works
Simulate and test your Grinding / Polishing operation on your PC. SprutCAM Robot has all that you need for it.
All the work is done in an interactive mode. The CAD/CAM system helps you to quickly create a grinding/polishing toolpath.
- Add a special operation – 5D Contouring
- Generate a toolpath
- Simulate and verify it
- Edit the toolpath interactively if necessary
- Start your robot with the G-code obtained
In SprutCAM Robot you can combine grinding / polishing with other operations. For example you can use grinding / polishing after a pick-and-place operation.
Use diverse equipment
The robot can hold a workpiece or a tool
Use various robots
SprutCAM Robot has a comprehensive library of 3D models and postprocessors for robots
Main features
for a productive workflow
Main features
Simulation in real time
In SprutCAM Robot you work with a 3D model of your robot cell. Because it’s convenient and visual.
Our library has more than 300 models of robots usable out of the box.
You can build your robot cell in our special app – MachineMaiker 2.0
Main features
Control additional axes
Besides the robot and CNC machine themselves, SprutCAM ensures control of an unlimited number of linear and rotary positioning axes.
Main features
Full Grinding / Polishing process control
Our Axis map tool helps to easily detect and bypass collisions:
- Envelope limitations;
- “Out of reach” cases;
- Singularities;
- Other collisions.
You can correct your toolpath automatically or do it manually selecting points on the curve.
