Clay milling with Kuka robot
SprutCAM X Robot is a versatile tool that enables users to create unique objects using various materials. From polystyrene to wood, metal to plastic, and even stone, there’s almost no limit to what you can make with this innovative robot.
But did you know that you can also use SprutCAM X to process natural materials such as clay? That’s right! With the right setup and technique, you can turn this malleable substance into complex shapes and designs.
Chen from Sprut Software Technology (Kunshan) Co., Ltd. (China) has used SprutCAM X to mill clay for a China BYD car, and the results are simply stunning. The precision and detail that can be achieved with this method are truly impressive, and we can’t wait to see what other users will create with it.
So if you’re looking for a new challenge or want to explore new possibilities with your SprutCAM X robot, why not give clay milling a try? You might just surprise yourself with what you can achieve!
CAD/CAM system for robots
All-in-one software for industrial robots programming
Industrial robot programming solutions
Grinding and polishing
Cladding
Got interested in SprutCAM Robot?
Install SprutCAM Robot
Download trial
Get a quote
Find Reseller
